Bug in MAX 4 on second display
I just found a bug in MAX 4. I tried to detach a database, but right-clicking with the mouse on a database in the tree view of the Citadel Universe didn't show any menu. Normally I run MAX on my second screen.
To test I just moved it to the primary one: and there it works perfectly!
So far I just found this problem inside the Citadel Universe tree widget. On other items it seems to work correctly.
Carsten
(2,590 Views)
I was able to reproduce the behavior on my machine and I will report it to R&D. Hopefully this issue gets fixed in one of the next releases.
Jochen Klier
National Instruments Germany
(2,573 Views)
Vielen Dank!
(2,563 Views)
