Bug in Measurement Automation Explorer 4.6.2f1?
after upgrading MAX to 4.6.2f1 (during installation of LabVIEW 2009 SP1 a.k.a. 9.0.1) I cannot change the names of devices in MAX. E.g. if I create a simuölated device, I cannot change the name from /dev1 to /my_device.
Did anyone encounter similiar problems with new MAX?
Marc
CLD
Message 1 of 8
(3,590 Views)
What happens when you right click and select rename? Do you want to programatically change the name?
Message 2 of 8
(3,559 Views)
I get an error message in German, which is translated to:
The chosen name is either not valid or already in use.
Both reason are not true. It is also not possible to delete the simulated device. For me it looks like as if I try to access a file, which I do not have write access, but I have the same problems with my administrator account.
Any ideas?
CLD
Message 3 of 8
(3,547 Views)
I tried your problem in my MAX 4.6.2f1 and had no problems to change the name.
Is there an error code in the error message? Can you post a screenshot?
Message 4 of 8
(3,532 Views)
I do not see this problem using 4.6.2f1 but did have my max database get corrupted recently (I had to wipe the DB and put in my devices again).
But I can add, rename both virtual and simulated devices on my version.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 5 of 8
(3,510 Views)
Here is the screenshot. Sorry, it is in German. I posted the translation above. No Error Code or something.
Marc
CLD
Message 6 of 8
(3,486 Views)
Accepted by Marc Blumentritt
Thank's for the screenshot. German is no problem for me.
It looks like a corrupted database of MAX.
Follow the steps in the following link. Perhaps that will fix your problem.
http://digital.ni.com/public.nsf/allkb/86256F0E001DA9FF86256FFD005B827C
But cleaning up the corrupted database will remove all configuration settings. The next time MAX is launched, you will have to configure all of your hardware again.
Message 7 of 8
(3,472 Views)
Thanks, this solved my problem. I just deleted the MAX data folder.
I already had my old MAX configuration in a backup, therefore reconfiguration is no problem.
Marc
CLD
Message 8 of 8
(3,460 Views)
