Bug on opening a template VI
If you open a template programmatically to create instances of a VI at run time. AND you have the preference set to record comments then the history window will pop up when you OPEN the VI reference. This can be confusing to a user! At worst it should not prompt for comments until it is saved. Since it prompts for comments at the open event there is no chance to set
This seems to happen for instantiating a reentrant VI as well. I have attached a small example. This was tested in LV 8.0.1 on Mac OS X. Someone please post if this bug persists in LV 8.20 or on other platforms.
LabVIEW ChampionLabVIEW Channel Wires
(2,553 Views)
1. In LabVIEW 8.0, I confirmed the behavior you described.
2. I tried this is LabVIEW 8.2 and I do NOT see the behavior - the dialog box does not open.
This is apparently fixed.
Best Regards,
JLS
Best,
JLS
Sixclear
(2,532 Views)
