Updating controls
In my application, the range of validity of a particular control is determined by other controls. How do I reset the value shown on the control to the maximum (or minimum) after the user has clicked the check button on the toolbar ?
Thanks.
(2,958 Views)
Can you give a small example of what you intend to do?
That would really helpful in understanding the problem
Regards
CLAD
Using Labview 5.1,6.1,7.1.8.0
(2,953 Views)
Clicking that or using the enter key is the same thing and is a value change event. So, use an event structure and do the resetting in the value change event of the control the user edits.
(2,949 Views)
