Bug with SV Software Triggering in Sound & Vibration Utilies palette ?
I would like to use the "SV Software Triggering (Analog Edge).vi" , available in the Sound &Vibration Palette, in the Utilities category, but it doesn't work properly or I do not use it correctly. I need to use this VI to trigger on an impact signal coming from a hammer (or other sensors) in a continuous acquisition mode.
I attached an example here where I generate a ramp signal with an increasing amplitude. The "SV Software Triggering (Analog Edge).vi" set the "new trigger detected" indicator to TRUE, but the "output ready" indicator is always false and the waveform is never returned.
Has anybody any suggestion to help me ?
Thanks in advance,
Mathieu
Message 1 of 1
(2,801 Views)
