Bug with SubVI Setup and LabVIEW 2011?
I set the SubVI Node Setup to Show Front Panel, Close Afterwards, and Suspend When Called. Calling the VI worked as expected, I then turned all of these options off and reran the VI. The subVI still paused, showed, etc. Saving, closing LabVIEW, reloading the VI made no difference. Doing a CTRL-Run fixed it.
(3,364 Views)
I notice the same behavior with my subVI set up Dennis.  Are you running Windows 7?
I am going to look into it further with our LabVIEW Engineers and whether this is a known issue.  If not, I'll make sure it gets in the correct hands.
Ben N.
Applications Engineering
ni.com/support
(3,314 Views)
I'm running Vista.
(3,312 Views)
@Dennis Knutson wrote:
I'm running Vista.
My condolences.
(3,293 Views)
I'm seeing the same thing under XP. I also noticed that you have to do a Ctrl-Run to get it to work the first time. Otherwise, the settings are ignored. LV2010 did not behave this way.
(3,290 Views)
