Build Application; enable ActiveX but get E_NOINTERFACE errors in C++
Hi
I have a hopefully easy problem to resolve using the Smart Pointers in C++ (VS2008).  So here goes...
I build a Labview application (MyExample.exe) based around my virtual instrument (MyExample.VI); and enable ActiveX with the server name 'MyExample'. I run MyExample.exe to register the full IID. In my code I do the following...
#import "d:\mypath\myexample.tlb" // to get access to the standard TLB file (same as doing #import "d:\program files\nationalinstruments\labview\...\labview.tlb"
MyExample::_ApplicationPtr m_pMyLabviewApp;
MyExample::VirtualInstrumentPtr m_MyLabviewVI;
HRESULT hr;
hr = CoInitialize(NULL);
// blah blah
hr  = this->m_pMyLabviewApp.CreateInstance("MyExample.Application"); // or with .7 for version specifics!
My application loads and starts up... However hr always returns E_NOINTERFACE, and the smart pointer m_pMyLabviewApp is always null.
However if I do the exact same code but replace MyExample with LabVIEW then it works perfectly. If I load 'MyExample.Application' in Labview using the ActiveX vi's it also works perfectly.Similarly if I use the Automation commands in Matlab.
My hope is that it is something trivial and dumb with the smart pointers... any hints?
(3,596 Views)
Accepted by topic author marc lawrence
Ok digging into the code a little more... the CreateInstance calls a various number of 'CreateInstances'... but the critical bit in comip.h...
line 623...
        if (dwClsContext & (CLSCTX_LOCAL_SERVER | CLSCTX_REMOTE_SERVER)) {
            IUnknown* pIUnknown;
            hr = CoCreateInstance(rclsid, pOuter, dwClsContext, __uuidof(IUnknown), reinterpret_cast<void**>(&pIUnknown));
            if (SUCCEEDED(hr)) {
                hr = OleRun(pIUnknown);
                    hr = pIUnknown->QueryInterface(GetIID(), reinterpret_cast<void**>(&m_pInterface));
                pIUnknown->Release();
The GetIID() function returns <LabVIEW::_Application>no matter whether I call with MyExample::_ApplicationPtr or LabVIEW::_ApplicationPtr - consequently the Query Interface will obviously be wrong. Now either this is a bug in my header chain (I will need to check all the .h and .cpp files) or there is something else strange with the importing of the .tlb file.
Or I am dumb and should use LabVIEW::_Application even with MyExample!
(3,587 Views)
I found the problem; and offending header also accidentilly included the Labview.tlb file. Consequently the call to the static variable GetIID which returns 'return *_IID;' returned the value stored in the Labview.tlb file and not the one from the MyExample.tlb.
Removing the incorrect #import "....\Labview.tlb" resolved the issue...
(3,581 Views)
