Build Array out of Experimental Points
maybe something like this?
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
Message 11 of 15
(1,266 Views)
OK.
Seems I didn't understand the purpose of the shift register.
Message 12 of 15
(1,265 Views)
Accepted by krwlz101
Hi krwlz,
a SR is (nearly) the same as your feedback nodes - the terminals of SRs are located at the loop borders...
You need to wire the array through the case in the false state AND you have to put the feedback nodes outside the case structure - then you get the same as in my example...
Do you really want to build a 2D array or do you want to get 1D arrays? Then you should switch the build array nodes to concatenation mode...
Message Edited by GerdW on 10-13-2009 10:41 PM
Message 13 of 15
(1,256 Views)
I feel like I'm from missouri.  Can you show me that?
Message 14 of 15
(1,248 Views)
Got it.  And what do you know, it all makes sense to me now.  Thanks so much.
Message 15 of 15
(1,244 Views)
