Build Array
Thanks everyone. If you guys don't mind, can we stick to the while and case structure scope for now. The VI is
still not working.
It seems the false case, is also outputing its value.
22453iFBAA74334807D64F
Message 11 of 21
(7,408 Views)
You switched the constant going to quotient and remainder to 0 instead of 20.
Tim Elsey
Certified LabVIEW Architect
Message 12 of 21
(7,404 Views)
Take a closer look at your Quotient and Remainder function.
Edit: Is there an echo in here?
Message 13 of 21
(7,402 Views)
Of course, this works fasterSmiley Happy
( finding all factors of an integer)
22455i09E03DFA932CE76E
Message 14 of 21
(7,396 Views)
22461i3713199F0B97B9FB
1 less iteration required since we know 1 and Numeric are factors we can skip that iteration and test 2 through
Floor (SQRT(ABS(Numeric)))
Message 15 of 21
(7,370 Views)
Thanks for the interesting challange- I went a step further to add this in my reuse code and added tests for perfection, primacy and squareness.  The special case handling (Number = 0 or 1) made it fun to test!
Enjoy!
Message 16 of 21
(7,347 Views)
I must be getting senile...
Did I miss something along the way?
I though the original OP mentionned the following:
"I expect the results:
0
1
2
4
5
10"
How can these be factorials?
Factorials would be:
0, 1, 2, 6, 24, etc.
not
0,1,2,4,5,10..
Yes, it's Friday and I probably missed something somewhere...
Message 17 of 21
(7,308 Views)
Factors, not factorials.
Jim
Message 18 of 21
(7,302 Views)
Right.  But this doesn't explain why he was expecting 0.  Seemed to be that he wasn't actually expecting it, since he never balked at any of our solutions.
Tim Elsey
Message 19 of 21
(7,299 Views)
<<<<<Mind reading>>>>>  is better than reading posts (sometimes)  Don't you wish every thread explained the end use requirement as well as this one did?
Message 20 of 21
(7,285 Views)
