Build CIN codes resource (.lsb file)
After reading the document:
How to build has CIN codes resource (.lsb file)
http://zone.ni.com/devzone/conceptd.nsf/webmain/31DAB548C369B2C6862567C8006D8FC9
I would like to know if it is possible to make the same thing with Microsoft Visual C++ 2005 Express Edition in the place of Microsoft Visual C++ v.5.0.
If that is possible, how to make?
Thank you
Denys.
(2,864 Views)
VS.NET 2005 isn't officially supported yet, although we are working on it. The problem is that Microsoft introduced the concept of Side-by-Side execution in regular DLLs (not just .NET), and that affects the way to correctly build the system.
I have an "unreleased" version of the make file that you can try if you are using LabVIEW 7 or 8. It isn't a VS.NET project, and I haven't tried it with the express edition, but I think it should work for you. What you need to do is back up your current <labview>\cintools\ntlvsb.mak file and drop in the one I've attached. Now just follow the documentation in "Creating a CIN", using a VC++ makefile (or using VC++ command line).
Let me know if you run into any trouble, because, as I said, this is a work in progress.
(2,853 Views)
Thank you Lycangeek for your assistance.
For the moment I use Labview 6.1, but we plan the update to version 8 in few weeks.
I keep your information.
Denys.
(2,846 Views)
