Build Program in LabVIEW 8.6
 How can I build a programm in LabVIEW 8.6?
(3,932 Views)
Thanks for all the detail you provided in your message.
I would recommend you learn more about LabVIEW from here. How to Learn LV
(3,909 Views)
I want to make an executable file (*.exe)
(3,905 Views)
Accepted by Matei
Then you need to use the application builder.  It comes with the Professional Development edition of LabVIEW, or is an add-on to the Full Development Edition or Base Edition.
You need to create a project file with your VI.  Search LabVIEW Help for "Building a Stand-Alone Application".  Also search the forums on the topic.  It's been covered many time before.
(3,899 Views)
