Build Specifications gone with LabVIEW 2009
I'm using LabVIEW 2009 and I still have the same problem as described in the following post (where all the answers were for older LabVIEW versions):
http://forums.ni.com/t5/LabVIEW/build-specifications-gone/m-p/625815
When I move a LabVIEW project from one PC to another, parts of the build specifications are gone. In the specification for the executable I have to redefine the start-up VI, the included files and the icon.
Is this a known issue and is there a fix for it?
(2,658 Views)
this might be a corrupt project file. Does this only happen with this project?
If so, then I'd suggest recreating the project and the build specifications on the original PC and trying to migrate it again to the other PC.
Joseph Tagg
(2,618 Views)
