Error? Formating a time string with %u gives always a , despite a %.;
I want a fractional part of a comma in my time string and used this format string:
%.;%<%S%3u>T
Because of my locale I'm getting in a common case a comma. But I want a point, so I used a %.; in my format string. But this isn't working. My LV is the last version.
(2,869 Views)
Hi.
I am a little uncertain if I understand the problem correct, so forgive me if this does notanswer your question.
If the desired format does return a comma in stead of a point you could use the Search and Replace String function to replace the comma with a point.
-Tom
(2,818 Views)
This is a 'forgetton' bug. Somehow it falls of the 'known issues' list for every release.
I have a bug filed here.
It turns out the decimal sign for the miliseconds is:
  1. Always shown
  2. Always the local decimal sign
I have a car 4I0EE2BQ  for this specific issue.
Ton
My LabVIEW Ideas
(2,806 Views)
Thank you!
(2,778 Views)
