Connection for load cell to NI9237
I have this omega load cell part LCKD-10 which is a half bridge load cell that I need to connect to the NI9237. Please advice on the connection.
Joelle
(3,311 Views)
Red -> 6
Black -> 7
Green -> 3
White -> 2
(3,295 Views)
Do I need to connect the resistors bewteen pin 6 to 3 and pin 7 to 3?
(3,273 Views)
no
(3,269 Views)
Thanks. I need to write out a program which checks the centrality of force. I will be using 5nos of the omega load cell, 1 in the centre(Isolated) and the other 4 at all 4 corners. I'm suppose to firstly calibrate the load cell and then take measurement of the force applied to the 5 load cell and display the result in a form of a radar graph (Just a dot in the centre of the graph to show the centrality of the force). Appreciate if you can provide some procedures or program that I can use or try out.
(3,262 Views)
