Build XY Graph
Hi everyone, i just want my XY Graph running smoothly for example if my graph x scale values reaches 20 then next 20 should come and previous 20 should discard.
plz see attached files
(2,208 Views)
Accepted by Akbar7110
At every iteration, take the last 19 elements of your arrays, then concatenate the new values.
Alternatively, if you want to start over, check the array size and reset it when reaches the desired maximum.
Also, get rid of the Express vi and the Dynamic Data: simply bundle X and Y arrays together and wire the result cluster to the graph.
Paolo
(2,195 Views)
Thank you very much
(2,187 Views)
