Build a Json with labview
Hello
I need to create a json in the following structure:
    "Value1": {
        "Build": {
            "1": {
                "t_inst": {
                    "Type": "Gold",
                    "Key": "15",
                    "size": "big"
                "1_avg": {
                    "Type": "Green",
                    "Key": "11",
                    "size": "big"
                "2_avg": {
                    "Type": "Blue",
                    "Key": "21",
                    "size": "big"
    "Value2": {
        "Build": {
            "1": {
                "t_inst": {
                    "Type": "Grey",
                    "Key": "22",
                    "size": "small"
                "1_avg": {
                    "Type": "Yellow",
                    "Key": "8",
                    "size": "big"
                "2_avg": {
                    "Type": "Blue",
                    "Key": "21",
                    "size": "big"
How can i build it?
I've searched several forums, but none I've seen have as many layers as I need.
Could someone help me?
Message 1 of 17
(1,552 Views)
Hello
I tried to put the json here, but it blocked my post
How can i build it?
Message 2 of 17
(1,573 Views)
Hello
Message 3 of 17
(1,570 Views)
1. Install the JSONtext library. This is an amazing tool for creating and reading JSON files in LabVIEW.
2. Build up a cluster with the structure you want and then use the To JSON Text VI to create the text. You can then save that text string to a file.
GCentral
Message 4 of 17
(1,541 Views)
Duplicated with Build json with this structure
https://tmesystems.net/
Message 5 of 17
(1,498 Views)
JSON Text is a toolkit I use for JSON work in LabVIEW
https://www.vipm.io/package/jdp_science_jsontext/
You start with modeling a cluster equivalent of JSON; then you can convert between cluster and JSON.
Santhosh
Soliton Technologies
Message 6 of 17
(1,494 Views)
Guys, do you know how remove the duplicates of my JSON?
I have 2 equipments and my code create 6 items on JSON
Please, help me
  "EQ1":{
    "TCP":{
      "1":{
        "test_t_inst":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":1,
          "Register":"Register",
          "Address":12345,
          "SizeLength":1,
          "FET":2,
          "Size":"big",
          "Conversion":"small"
  "EQ1":{
    "TCP":{
      "2":{
        "test_1_avg":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":2,
          "Address":36871,
          "SizeLength":1,
          "FET":0,
          "Size":"big",
  "EQ1":{
    "TCP":{
      "3":{
        "test_2_avg":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":1,
          "Address":24572,
          "SizeLength":1,
          "FET":0,
          "Size":"big",
  "EQ2":{
    "TCP":{
      "1":{
        "test_t_inst":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":2,
          "Address":32451,
          "SizeLength":1,
          "FET":0,
          "Size":"big",
  "EQ2":{
    "TCP":{
      "2":{
        "test_1_avg":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":1,
          "Address":27789,
          "SizeLength":1,
          "FET":1,
          "Size":"big",
  "EQ2":{
    "TCP":{
      "3":{
        "test_2_avg":{
          "Type":"ABC",
          "IP":"192.168.0.0",
          "Port":111,
          "Still":2,
          "Address":11234,
          "SizeLength":1,
          "FET":1,
          "Size":"big",
  "user":"johnCena",
  "token":"327AD8E61A4F6EB329CE5190E",
  "password":"TheLastOfUS"
Message 7 of 17
(1,444 Views)
Your 2D array constant on the BD has 6 rows.
I think you need to connect 'Array In' to the code instead of the constant.
Message 8 of 17
(1,436 Views)
Yeap, but the constant it's only for test
The data entry it's coming on this format
Message 9 of 17
(1,431 Views)
Sorry, I don't see your problem.
The constant has 6 rows resulting in 6 EQ entries in the JSON string.
If I cut the constant to 2 rows the resulting JSON string has 2 EQ entries.
Message 10 of 17
(1,424 Views)
