Build a exe file with niimaqdx.dll
Hello, I want toask about how could I build up a exe file with    niimaqdx.dll    nivissvc.dll    nivision.dll
because when I copy the package including application & installer to the PC without LabVIEW,
after open the application, the causion jumps out and mentions about there are no those dll file, how could I fix this problem?
I tried to check those options like the first picture
but  it seems that  I have to select source...
Does anyone know about this?
thanks!
(4,553 Views)
Accepted by topic author mei0512
-Assuming you have taken proper licensing options: https://www.ni.com/en/support/documentation/supplemental/18/licensing-national-instruments-vision-so...
-You can Manually Transfer or Download the Vision Run-Time Engine, NI-IMAQdx, and NI-IMAQ to Target Machine: https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4qECAQ&l=en-US#toc6
uday
(4,543 Views)
