Build a waveform of N samples with zero amplitude?
Can anyone describe how to build a waveform of N sample length with zero amplitude?
Message 1 of 9
(3,723 Views)
Accepted by topic author super-neuron
One way is to just use an Initialize Array and a Build Waveform.
Message Edited by Dennis Knutson on 07-30-2008 05:32 PM
Message 2 of 9
(3,720 Views)
Do not forget to put in dt if timing will be important for later usage of the waveform. I think the default is 1.
Lynn
Message 3 of 9
(3,697 Views)
Thank you Dennis & Lynn!
I believe I got it.   Does the attached example look correct?
Sincerely,
zach
Message 4 of 9
(3,684 Views)
There's no attachment. Do not select preview after doing an attachment.
Message 5 of 9
(3,680 Views)
Yikes!   My apologizes.  Here it is...
Message 6 of 9
(3,678 Views)
It looks okay to me.
Message 7 of 9
(3,672 Views)
zach,
It looks OK. Typically people do not put the error clusters in other clusters. Usually the errors are handled separately, but there is nothing wrong with your way if that is best for what you are doing. I put a Waveform Graph on the panel so I could visualize the result. It appears to be what you were asking for.
Lynn
Message 8 of 9
(3,667 Views)
Dennis & Lynn,
This works great.   Thank you both for your advice and examples.   I really appreciate the help you've given me, and your ongoing work in the forum community.   Great hardware, great software, and a rocking community of people.   I'm so glad we chose NI.
Have a great day!
zach
Message 9 of 9
(3,662 Views)
