Build error
In the build log just before the error is the last VI (yours) that LabVIEW was processing before this error occured. This isthe one that needs "fixing".
Br, Mike
Message 11 of 21
(7,931 Views)
Accepted by Alain_S
Titou's first idea was closest of all suggestions Smiley Surprised
I delete the 3 project files (MyProject.aliases, MyProject.lvlps and MyProject.lvproj) and create a new project with the same vi's, typedef's, .... ... all in the same folder.
No more errors while creating the EXE file 🙂
Message 12 of 21
(7,922 Views)
I have a Shared Variable published by a Shared Variable Engine on a remote node. I would like to diagrammatically access the alarm limits , of that Shared Variable. But using property node on remote machine i got this error. 1967362032. Can anybody tell me how to do this in better way
Message 13 of 21
(7,822 Views)
Hello SSRaza,
At the following link you can find more information about the error -1967362032:
http://digital.ni.com/public.nsf/allkb/96C5B8A73F624996862576CF00611A41?OpenDocument
"Shared variable alarm properties are only accessible from the PC hosting the shared variable. There is, however, a workaround. It is possible to view and read properties using a DataSocket Read or DataSocket Write VI"
At the following link you can find more information about DataSocket: http://digital.ni.com/public.nsf/allkb/8D2FE9AC6ACB8B3F862571B0007FAECA?OpenDocument
Also on our website ni.com, there is extra information when you search on DataSocket
Kind regards,
Nico Lammens
NIBE AE
Message 14 of 21
(7,808 Views)
Unfortunately it did not help me with the same error. Any other ideas?
Message 15 of 21
(7,506 Views)
Getting Error vieweing the document: "You are not authorized to view this document"
Message 16 of 21
(7,505 Views)
Hello Vladiator,
Which type of error are you getting?
What does your code look like?
Kind Regards,
Thierry C - CLA, CTA - Senior R&D Engineer (Former Support Engineer) - National Instruments
If someone helped you, let them know. Mark as solved and/or give a kudo. 😉
Message 17 of 21
(7,491 Views)
Thanks 🙂
Turning on the build log identifies the file causing Error 56003.
Otherwise you are working in the dark
Message 18 of 21
(6,350 Views)
This may or may not help anybody.  I had a SFVA Sound and Vibration Analysis Toolkit that would cause a build error.  I had tried mass compile and repairing the toolkit.  Neither worked.
I had built multiple versions revisions of software, and suddenly it stopped working.
I decided to run the offending vi.  And the error being thrown matched a similar error I would get with an empty array.  So I changed the default control array from empty to having a single element.  Then the software compiled without a problem.
I am not sure if changing the array made the difference or just changing the file and saving it again.  Again recompiling it and saving it did not fix the problem.
Message 19 of 21
(5,426 Views)
I had a similar issue. Turns out my project was referencing some vis that were not on disk. Even though they had no callers, the build would not execute and the error message was maddeningly vague. Only once I opened the build spec, changed something and then tried to save it did I receive a notification that some referenced vis were missing.
After deleting them, the build worked fine!
Message 20 of 21
(5,169 Views)
