Build exe with report generation 2011
Im  using Labview 2011 with Report generation Toolkit 2011. In my Labview project i added report LV classes HTML, Word, Report, Standard report.LVclass. after building exe  it creates many folders of vi which are supporting files from report generation toolkit.
in this project i am using Word report generation only. can you please guide me which are lv classes i need to add in the project and also tell me how to avoid to generate these kind of folder while building exe.
Balaji DP
Message 1 of 15
(5,331 Views)
Can you please let me know how you are creating project.
Hope this attached file will work good for you..
I dont think it should create any additional files.
Try like this & let me know
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 2 of 15
(5,309 Views)
hi,
Can you explain me what exactly i need to add in to the project if i used report generation toolkit.
also explain me that while creating a executable file what are the files to be added.
if you have user manual please share it .
i have enclosed my project tree which i have added for report generation lv class, please look in to that.
Balaji DP
Message 3 of 15
(5,293 Views)
Check my project file , i have added same look like your project.
also find build specification
Balaji DP
Message 4 of 15
(5,286 Views)
Include this folder in your project: <LabVIEW>\vi.lib\Utility\NIReport.llb
You may also need this one: <LabVIEW>\vi.lib\Utility\LVClass
In the application builder, tell it to include these entire folders.
Message 5 of 15
(5,286 Views)
i have included as LVClass and NIReport folder. but while creating a exe i am getting too many folders
Balaji DP
Message 6 of 15
(5,283 Views)
Try like this,
HOW TO LIBRARYS TO A PROJECT?
  • Open the project window.
  • Right click on the my computer.
  • Add à folder (Snapshot).
  • Go to C --> Program files --> National instruments  --> labVIEW 2011 --> vi.lib --> Utility --> open LVClass --> press current folder
  • Repeat the same procedure for NIReport.lib.
                                                            OR
          C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\Utility\NIReport.llb\
          C:\Program Files\National Instruments\LabVIEW 2011\vi.lib\Utility\LVClass.llb\
Let us know.
--Ranjeet
Message 7 of 15
(5,249 Views)
Please find a screen shots, enclosed zip files.
i have added LVClass and Report.llb by snapshot.
after build exe preview it generates NI_Excel, NI_HTML,NI_report......support0 support1 support2....
Balaji DP
Message 8 of 15
(5,244 Views)
Send me your project file if it is ok with you. I will try to rectify. By seeing images this is bit difficult.
--Ranjeet
Message 9 of 15
(5,237 Views)
sorry, i cant able to send you whole project, it has more than 4000 Vis.....
if possible can you send me the user manual for building exe with report generation tool.
otherwise if possible please share your contact number
Balaji DP
Message 10 of 15
(5,230 Views)
