Build exe with report generation 2011
Give me your email ID
Kudos are always welcome if you got solution to some extent.
I need my difficulties because they are necessary to enjoy my success.
--Ranjeet
Message 11 of 15
(757 Views)
dpbalaji@gmail.com
Balaji DP
Message 12 of 15
(748 Views)
Try this example project. Look at the source file settings (especially dependencies).
Build it.
Hope this helps.
CLA CTAChampionI'm attending the GLA Summit!
Subscribe to the Test Automation user group: UK Test Automation Group
Message 13 of 15
(742 Views)
I had a problem with this before.
This is how I solved it:
Make sure that "Use Labview 8.x" file format is unchecked, that is what is making you have all kinds of folders.<LabVIEW>\vi.lib\Utility\NIReport.llb, and <LabVIEW>\vi.lib\Utility\LVClass need to be included.
Message 14 of 15
(725 Views)
Now its works fine but i have some dynamic vi which i have added in my project file viserver/call.vi. If i checked 8.x file setting it will load correctly but if i unchecked its not loading showing file not found, how to resolve this
Balaji DP
Message 15 of 15
(707 Views)
