Build name conflicts (NI Report Generation Toolkit)
When I remove "build as LV 8.X" and call report functions appear that message:
But then set  "build as LV 8.X" all work fine.
Message 51 of 71
(3,601 Views)
Does this apply? If what you're seeing is not a bug, this probably means that at some point the dynamic files were included in the 8.x build, so that they are already found where you're looking for them.
___________________
Try to take over the world!
Message 52 of 71
(3,579 Views)
I can't this apply, on compile error.
 But my error is only on labview2009 x64, on x32 all ok without "build 8.x".
Message 53 of 71
(3,573 Views)
If you can reliably reproduce this in a simple project, I suggest you start a new thread, attach a project others can test and then link to it here.
___________________
Message 54 of 71
(3,568 Views)
The error appear then press button only in x64 exe without "build as LV 8.X".
The project in attachments.
Message Edited by _Cyber_ on 12-24-2009 04:41 PM
Message 55 of 71
(3,545 Views)
Again, I suggest you start a new thread and add a link to it in the bug thread. Otherwise, the people who need to see this will probably not see it.
___________________
Message 56 of 71
(3,534 Views)
It might be related to this: http://www.ni.com/pdf/manuals/371780e.pdf#page=46
To clarify, you're getting the error at runtime, but the build is successful?
Jeff | LabVIEW Software Engineer
Message 57 of 71
(3,486 Views)
Yes.
Message 58 of 71
(3,479 Views)
What is your operating system and service pack level? You have both 32 and 64 bit LabVIEW installed on that machine? Or are you testing on multiple machines?
Message 59 of 71
(3,451 Views)
Win7 x64. I have both 32 and 64 labview2009. The 64 bit exe was tested only my machines with win7 x64. The 32 bit exe was tested on Win7 x64 and WinXP x32. The 32 bit exe work fine.
Message 60 of 71
(3,447 Views)
