Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
Building Executables using DAQmx VIs
Trupti
Member
09-20-2005
08:35 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
I am building an executable from a VI which uses NI-DAQmx VIs. I will be installing this executable on a machine that only has the driver installed. When I build the executable in LV, do I have to include DAQmx VIs as support VIs?
----trupti
0
Kudos
Message
1
of 2
(2,815 Views)
Reply
Re: Building Executables using DAQmx VIs
Travis_W
Member
09-21-2005
04:01 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Trupti,
All you need is to have the DAQ Driver and the LV Run Time Engine installed on the target computer. It is not necessary to include the DAQ VIs.
Travis W
DAQ Enthusiast
0
Kudos
Message
2
of 2
(2,791 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
