Building Executables using DAQmx VIs
I am building an executable from a VI which uses NI-DAQmx VIs.  I will  be installing this executable on a machine that only has the driver installed.  When I build the executable in LV, do I have to include DAQmx VIs as support VIs?
----trupti
(2,777 Views)
Trupti,
All you need is to have the DAQ Driver and the LV Run Time Engine installed on the target computer.  It is not necessary to include the DAQ VIs.
Travis W
DAQ Enthusiast
(2,753 Views)
