Building a case structure with four boolean (true/false) inputs.
I currently have two boolean inputs that I would like to use to select cases in a case structure. I would like to have four cases, each one dependent on the true/false condtions of the two booleans. If boolean 1 =true, then case 1 should be used, if boolean 2=true, then case 2 should be used, etc.
What structure should I use to convert these boolean inputs into numeric cases?
(6,092 Views)
Build your two booleans into an array. Then use boolean array to number.
PaulG.
Retired
(6,082 Views)
Accepted by KFod
Build Array for the two Booleans and then a Boolean Array to Number.
(6,080 Views)
Accepted by KFod
Or build them in to an array and "Search 1d Array".  If you are only looking for a single bool being true, this would be easier because your cases could be {0,1,2,3} instead of {1,2,4,8}
(6,074 Views)
Change the radix on the case selector to boolean if it makes more sense to view the cases as 1's and 0's rather than base10 numbers.
aputman
(6,020 Views)
