Building a .rtexe Takes an Unreasonable Long Time
Here's some interesting images to ponder about.
Starting the build:
And when the build finished (with errors, sometimes this happens for no apparent reason):
Fantastic, waiting for 6h for the build to error out on me (that VI is perfectly fine).
LabVIEW: the ultimate rapid-prototyping toolkit!!!
Br,
/Roger
Message 11 of 13
(659 Views)
Ah, after some serious coffee devouring and with much thanks to the awesome Intel Core i7 3+MHz CPU cycles grinding away for 6hours on the O(n^3) complexity LabVIEW application builder
So I have finally traced down the application builder bogus errors. With no further ado, below is the solution.
This wickedly simple and straight forward labview code wasn't apparently good enough for the application builder.
Below is how I did solve this with my usual trickery and hackery LV workaround mentality of lately.
So it seems like generating waveforms bugged out the application builder?
Wow! Smiley LOL
Br,
/Roger
Message 12 of 13
(645 Views)
Is the absurd slowness of the application builder in large projects not an important issue for NI?
Well, now that I think about it, apparently not. Smiley Mad
Br,
/Roger
Message 13 of 13
(571 Views)
