Building a square wave by adding harmonics
I'm trying to create a Fourier Series to build a square waveform by adding the harmonics. But, after I implement the functions into the software, there are some errors in the output and i cant get the square wave output.
I've attached the vi and the document containing the expected output from the vi.
Please take a look
Edward
(3,771 Views)
   hi, i can't see the VI cause i've 8.0 and the version of your vi is higher, but i built this little vi I've attatched based on the word's document, maybe it's what you need. Bye.
Paul
Mechatronic engineer
Lima-Perú
(3,758 Views)
Thanks Paul 🙂
that one is really helpful
(3,751 Views)
