array rotation
hi, can anyone know the labview code for the rotation of a 1D array without using ROTATE 1D ARRAY function.
Message 1 of 10
(5,133 Views)
Yes, but the only reason that I can think of why anyone would try to do such a thing is either for a mental exercise, or a school assignment.  The latter would be the only reason that would elicit a question here. Smiley Happy
Jim
LV 2020
Message 2 of 10
(5,124 Views)
Hi Anupama.U…,
there are different ways. Can you please explain, why you need it?
Mike
Message 3 of 10
(5,123 Views)
Hi Anapuma,
these are two possibilities…
greets, Dave
Message Edited by daveTW on 05-27-2008 01:07 PM
Greets, Dave
Message 4 of 10
(5,121 Views)
HI, Thanx for ur support.Actually i'm new to this tool and wanted to do more exercise on this tool. Thanx Anupama
Message 5 of 10
(5,112 Views)
Actually, learning about the tool or language is to actually use the functions that are available.  It's much better and more efficient as a programmer.. 😉
Message 6 of 10
(5,101 Views)
Message 7 of 10
(5,062 Views)
Hi Anupama,
Why an empty reply? Smiley Happy
What does this mean? Smiley Indifferent
- Partha ( CLD until Oct 2027 🙂 )
Message 8 of 10
(5,059 Views)
HI,
It just happnd becoz of my mistake.
i didnt noticed that.
Anupama
Message 9 of 10
(5,055 Views)
Well, it is a useful exercise trying to emulate a built-in LabVIEW function. It gives you a chance to fully understand the function AND the tools you are using to duplicate the functionality.
In particular, you should make sure that your replacement function works identically. E.g. try with an array of size=5 and e.g. rotate by -999, -998, -2, 0, 2, 998, or 999 and see if you get the same result as the built-in rotate array in all cases. Try with an empty array, etc.
You can also do some benchmarks to see how much more efficient the LabVIEW function is compared to your contraption. (Maybe you can even try to beat it. Long ago in the "median challenge", several entries were faster than the stock median VI of LabVIEW if I remember right. ;))
Here are two quick mockups. Try to make a few more, e.g. one containing a shift register or the in-place element structure.
Message Edited by altenbach on 05-27-2008 11:41 PM
Message 10 of 10
(5,042 Views)
