Building a stand alone program for computers with no LabVIEW installed on them
A new client is asking me to build a fairly simple application that communicate with a measurment instrument, takes the produced result text file and sort it nicely in excel (later, data analysis might be added).
I do not have a LabVIEW subscription and neither does my client. They are willing to buy a one year subscription for me to work on, only if the program can later work on any given PC without the need of LabVIEW environment.
I have built an app with LabVIEW before (my previous client had an add-on), but I am quite sure that executing the .exe file required LabVIEW installed on the computer.
My question - is there a way to build a stand alone app for my client to distribute in all of his PCs (windows) without the need of LabVIEW installed on them?
This is my first independent job as a LabVIEW prgrammer so I still don't know much on such matters.
Thanks for helping.
(2,403 Views)
You don't need LabVIEW, you need the LV run time engine.
You can include the run time in the installer.
The RTE has no license cost.
Making a LV executable that runs without installing the RTE is hard (e.g. don't even try).
(2,375 Views)
Accepted by Aqua-
As @wiebe@CARYA said, you need runtime engine, which is free (and can even be installed on a PC using an installer you can make)
That said, you need a license that includes Application builder in order to make .exe files and installers.
I think you can use base development license with Application builder add-on, but depending on other add-ons you might needs it would probably be worth it to buy professional edition. You should probably ask your local distributor about it.
(2,356 Views)
Thanks @wiebe@CARYA and @AeroSoul for your reply.
As i mentioned in my OP I have already built an .exe file from a complex VI that included around 15 subVIs. However, I have'nt build a complete installer.
Can you please direct me or send me to a guide on how to create a complete stand alone installer for a program?
about the license - from the I've seen in the NI shop indeed the LabVIEW Base should be enough for my client in terms of features, with an additional add-on called LabVIEW Application Builder Module.
Since they count on me to tell them what is needed I want to be perfectly sure - do you know if I will be able to read a produced text file and export it as an xls file including formatting, headers, etc. with these LV packeges?
Thanks again for any replys
(2,325 Views)
How to make installer
Text files should be fine with base Labview, but the xls might need NI Report Generation Toolkit (i know for sure Word documents do).
(2,320 Views)
