Building an application(Exe)
Hey guys i am trying to build an application of my VI's in labview 2012 but there is no option of application(exe) when i right click build specification even though i have saved the project. Kindly check the attached snapshot.
(4,352 Views)
Do you have Application Builder installed and activated?
What do you see, when you open NI License Manager (..\Program Files (x86)\National Instruments\Shared\License Manager\Bin\nilmUtil.exe)?
Application Builder
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(4,336 Views)
Application Builder
(4,329 Views)
I think its not installed right, do i have to install it seperately?
(4,328 Views)
Accepted by Awais07
If you buy and install, LabVIEW Professional or LabVIEW Development Suite, Application Builder is included otherwise you need to install it as a separate add-on.
Refer to:
https://www.ni.com/en/shop/labview/select-edition.html
(4,322 Views)
Thankyou, I will install it as a addon then.
(4,316 Views)
