Building an array from a for loop.
Hi all
I have a vi which reads from a file and manipulates the data using for loop. I am taking each element and multiplying it with a constant and converting it to I32. I would like to build back to a new array with the new values. I have attached the vi and a sample data file to read from.
Please suggest if there are any better ways to do this.
Thank you.
(3,835 Views)
Accepted by avinash3010
You can multiply the array with the constant and use the array instead of multiplying it with each element.
(3,829 Views)
Hi Anand
Thanks again...I never thought numeric would work on arrays as well..
(3,826 Views)
But what is the way to convert each element into I32..???
(3,824 Views)
Just pass the array through I32 the whole array wil be converter
(3,814 Views)
(3,813 Views)
