Building an executable hangs Labview
Accepted by Bob_Schor
What is your I: drive? Network drive? Thumb drive? The last line of your build log shows a source file that exists in your I: drive. If you've tried every other suggestion, I would move that file somewhere on C: and try again.
Or before that, make another simple VI and try to build it, but include that VI that exists in the I: drive, it's located at (get ready)...
I:\Projects\WTK\Hardware - Layout - Labview\cRIO - MyRIO\Microman Laser Setup - Krishna\Microman V3\Analog Discovery\Digilent_WaveForms_Stimulus Response (MSO + DIO Tom).vi
If that VI can be built, then I guess nevermind 😅
Redhawk
Saying "Thanks that fixed it" or "Thanks that answers my question" and not giving a Kudo or Marked Solution, is like telling your waiter they did a great job and not leaving a tip. Please, tip your waiters.
Message 11 of 12
(1,186 Views)
Hi RedHawk,
Moving the build location to c:\ was indeed the solution.
However, like you suggested, i also made a simple .vi (switch and indicator) and this was able to be build onto the network drive.....
So finally, case closed.
Thanks all.
Message 12 of 12
(1,181 Views)
