Building exe in LabVIEW 2009 using report generation toolkit
Hi all,
While making an exe in Labview 2009, it creates report generation related folders where my application is.
I have included _Excel Dynamic VIs.vi in always included tab...still I get same folder structure. Smiley Sad
Can anyone tell me how can avoid it?
Gaurav k
CLD Certified !!!!!
Do not forget to Mark solution and to give Kudo if problem is solved.
(3,479 Views)
Have you tried changing the default destination for the files in the build specification?
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,473 Views)
What it should be?
Gaurav k
CLD Certified !!!!!
(3,469 Views)
It doesn't have to be anything. You said that what you had was not correct, so what do you want the directory structure to look like?
Mike...
LabVIEW Champion
(3,467 Views)
Those folders are created automatically while making exe.. Its not like I have them in my project and assign destination in build specification.
Gaurav k
CLD Certified !!!!!
(3,465 Views)
So what is the problem? Is there a reason you don't want them? If not, don't sweat it.
Mike...
LabVIEW Champion
(3,456 Views)
If I trust my memory, When I use to create exe with LabVIEW 8.5, and include _Excel Dynamic VIs.vi, this folder structure did not form..
I was just thinking why it does with LV 2009.
I thought I am making some mistake or missing something. Anyways, Thank you, I guess from your post it seems I am not doing anything wrong.
... Smiley Wink
Gaurav k
CLD Certified !!!!!
(3,438 Views)
