Built installer fails - older version of winMIF
Hello I cannot install my application.
I have followed the recommendations. I have tried in 3 different laptops, 1 of them have Labview installed. I am currently sending the data from one of the laptops without it.
I confirm that it says "no operation..."
at first there were some packages and I installed them. I am not sure what this advice means "If it does not show the above message, but appears to install some packages, please retry your build and install in LabVIEW - as it might be fixed now." What do you mean to retry the build and install in LabVIEW?
I still get this problem:
and here is the details of the .dll
I have this features in my laptops:
As I said, this happens in 3 laptops already. I dont know what do to. Could someone help me with this?
Message 31 of 35
(973 Views)
Forgot to say, unfortunately I cannot share the installer due to company policies. Do I have to install LabVIEW? I have never used it, I just need to run the application as a user
Message 32 of 35
(967 Views)
See WinMIF Not Compatible With .NET 4.8 Error When Deploying Custom Installer for more information on this issue.
Scott Richardson
https://testeract.com
Message 33 of 35
(965 Views)
I tried every step that's in this post, but the issue still persists. Installing NI ADE Deployment Support didn't work. Is there any other solution? Thank you.
Message 34 of 35
(922 Views)
I'm trying to download this zip, but this zip is invalid.
Message 35 of 35
(625 Views)
