Butterworth Filter Calculation Time in LV
I have found very strange behaviour of LV butterworth filter. If I use signal some AC signal first, followed by DC (zero) samples, then calculation time increases from aprox. 0 ms to 10ms. Using WinXP or Win2K and LV6.1 or LV7.0 with the same results.
Please see example at:
http://dvi.elcom.cz/~bilikp/TestFilter.vi
or make your own example. Does anybody have idea what can be wrong? Thank you in advance for any help.
Petr Bilik
(3,841 Views)
I'm using LV7.0 on WinXP.
Your example shows a flat "0" in the CalcTime display.
Les Hammer
(3,841 Views)
I tried it again on 5 indenpendend PC computers, always with same results in LV6.1, LV7.0, LV7.1. I even changed my example to find out behaviour of different filter types. High calculation time phenomena is just a question how long this example runs. Anyway on normal PC (P4/2GHz) you can see it in 30seconds.
Please see new example at:
http://dvi.elcom.cz/~bilikp/TestFilter2.vi
Petr Bilik
(3,841 Views)
In the meantime I tested this example under Linux version of LV7.0, using Linux Mandrake 9.1. Again I got high calculation time after few seconds of run.
(3,841 Views)
Ah, I see what you mean. Your original description was confusing. I thought it was the 0->1 transition that was the problem, not 10 seconds later.
Sorry, I don't have an answer for that one yet.
(3,841 Views)
And the high calculation time happens sooner if you initialize the arrays to a larger size, and later or not at all if you make the arrays smaller.
Looks like a memory manager issue to me.
Les
(3,841 Views)
I looked at the state of the filter when the change in execution speed occurs. The state is very small (~ E-322), and does not change. It looks like the filter output is decaying to zero, and reaches a point where the filter numerics underflow. If you add a very small amount of noise to the zero-input-signal the behavior disappears.
(3,841 Views)
