Buttons and 3 Menus...
How to use buttons to control the 3 menus and submenus by not clickin the plus and minus?
What tools do i have to use?
(2,816 Views)
Hello Kaka77
if you go to the properties of your menu ring, the last submenu in there is called key navigation (it is after documentation and data binding. a bit hidden you have to press the forward button in this properties menu).
this key navigation allows you to focus to the menu using any key you want, then to use any other key for incrementing and decrementing.
Does it help?
Gabriel
... And here's where I keep assorted lengths of wires...
(2,813 Views)
I mean how to create this kind of menu and buttons.
(2,808 Views)
