Byte array to specifier Type
Hello everyone.
In my project I have a connection to an external device through an RS-232 connection. Now I read the bytes and want to convert these to a specified type, like I32 or U8.
When data arrives, i convert the string to a byte array. For one portion I have to convert a array of 4 bytes to an I32. This means that the bytes are litterary the data that has to be converted into the data type.
I have no idea how to do this, could you guys please help me?
Kind Regards,
Jesse Bax
Swissdrones Operating AG
Message 1 of 15
(6,657 Views)
How I understand Your task, You want somethink like this
With best regards
Certified LabVIEW Architect (CLA)
Message 2 of 15
(6,632 Views)
I would use the Unflatten From String to convert directly from the VISA Read's string output.  That function also lets you choose the Endianness of the I32, which is why I would use it over the Type Cast function.
Message 3 of 15
(6,629 Views)
Yes,
Thank You, Like this
With Best Regards
Message 4 of 15
(6,623 Views)
Sorry I made my question a little vague. The string I get is not for just one number, but multiple. See attachment for contents.
As you can see, there are 15 variables i have to convert from the string to data. In the 3rd column it says "type", this is the type where the data fits in.
When i do it wrong, for example: 1000001bin
When i convert this Byte to an U8 then the decimal number would be: 129
when i convert this Byte to an I8 then the decimal number would be: -127
now for my problem the data that i receive already represents the values of the specified type, only i want to make it so that labview knows what data type it is
Kind regards,
Jesse Bax
Message 5 of 15
(6,594 Views)
This is exactly what the built-in function "join Numbers" is for.
Take a substring of the first 4 bytes and convert the bytes to I8 with a cast or string to byte array and then change to I8.
For the next 6 values, take groups of 4 bytes and change Join pairs to get two 16 bit numbers and join those to get 32.  The order they are joined depends on if the instrument is sending big endian or little endian values.  But you should be able to figure out from the data stream the order to combine things to get the value. Convert it to I32.
For the next 9 values just take pairs an "join Numbers" to make 16 bit integers.
Join Numbers is your friend here.  It is on the Numeric->Data Manipulation palette.
LabVIEW ChampionLabVIEW Channel Wires
Message 6 of 15
(6,583 Views)
Accepted by Feignedjesse2
That's too much work.  Just create a cluster of all of the data in the message and Unflatten From String will do everything for you.
Message 7 of 15
(6,563 Views)
If and only if, the endian of the receiving machine is the same as the transmitted byte order.  Endian issues are still around.
Message 8 of 15
(6,554 Views)
Yes, but "Unflatten from String" has an endianness input, so it can be switched while unflattening.
Message 9 of 15
(6,549 Views)
Right, I had forgotten that.  I use the unflatten for my network communication, but got in the habit of join numbers for dealing with odd instruments.
Message 10 of 15
(6,545 Views)
