Bytronic Simulation Model Gauging Head advice
Hi all,
I've been using the Bytronic Simulation model over the last few weeks and
i'd like to get the gauging head to work.
I can manage to activate the clamping action on the gauging head since it
uses the same 40 way MPCT4 cable, and hence uses Port A bit 5. But i'm
having problems reading in from it, i've looked in the manual but cannot
seem to work out the base address for this operation.. where am i going
wrong?!
Note. The base address of the cards are set at default.
hope someone can help
(2,796 Views)
Is there a LabVIEW question you have?
(2,796 Views)
D,
I would suggest contacting Bytronic for this kind of information.
Randy Hoskin
http://www.ni.com/ask
(2,796 Views)
