C Code Generator and Pic Microcontroller
Hello everyone,
I found couple threads discussion on how to use C Code Generator from LabVIEW to create code that could be compiled to HEX and programmed into Pic Microcontrollers.
However, it seems that no one had sucessfully achieved that. I believe that assignig IO, config header and oscillator frequency should be challenging.
Does anyone could provide me any information on how to proceed to achieve that? I wrote a simple VI and converted it to C using the C Code Generator, but I have no idea what I have to adjust into C code in order to have it working on my Pic Microcontroller.
Dan07.
(3,990 Views)
Hi Dan07,
I see no one has commented on this for a few days so I'll throw my 2 cents in. The limited experience I have with the c code generator is pretty much to not use it. LabVIEW does a lot of things for you that would result in a runtime error for C code. An example of this is accessing an array outside of it's index, normally this will give you a runtime error in C,whereas, LabVIEW will just return a zero.
I found there's a lot of that going on in the background so going through the code to try and extract your algorithms or changing specific parts can be really challenging. Personally, I'd get a cRIO to run LabVIEW programs natively or just write your code in C to begin with.
There are a few tutorials to get you started with the C code generator. Linked below, I guess if you have to go down that route they'll be your best starting points?
http://www.ni.com/tutorial/11784/en/
https://www.ni.com/docs/en-US/bundle/labview-c-generator-module/page/lvcgenhelp/cgen_lvcgenhelpdocin...
Sorry I can't really help with this one 😕
Daniel Harryman MEng
CLA, CPI
(3,929 Views)
