Its possible embed a TestStand User Interface into a Subpanel
Hello to everybody. I am developing a User Interface for TestStand. The system will have another VIs to control hardware which is not needed to execute the test but is necessary for some functionalities of the system. My question is if I can embed the User Interface for TestStand with the another front panels in a SubPanel. I have understood that TestStand User Interface must be run in the User Interface thread ,moreover, the TS User Interface uses ActiveX calls and I do not know how it can affect the inclusion of a TS UI into a subpanel.
If it is not possible I would appreciate their suggestions to done this kind of task.
Thanks for your time and help.
(3,119 Views)
Why don't you "merge" the both VIs to have a single interface VI?
Norbert
Norbert
Expert: Geometry
(3,087 Views)
