C Problem in VI
If you want us to help more, you need to tell us how the formula was derived or where you got it.  Based on the code in your formula node and those values for the inputs, maxAch will be smaller than 2E6 until bit <= 12 (with all other inputs unchanged). If that is not what you want, the formula apparently has an error.
Lynn
Message 21 of 24
(679 Views)
Lynn, can i ask where you get "bit <= 12" from?
Message 22 of 24
(668 Views)
I changed the value of bit in the VI I posted yesterday until maxAch became 2E6 and stayed there.
Lynn
Message 23 of 24
(661 Views)
Yeah i see that now, thanks. I'll take  alook againa t this now, and see what the story is.
Message 24 of 24
(622 Views)
