C Series Digital Module NI-9403 DIO configuration
Hi all,
I was wondering what the ratio of DIO's is when you set the initial line direction.
I have had experience with the NI-9401 and here you can set the first four and the last four to either input or output.
Is this the same for the NI-9403 or is this split into 16 and 16, if that is the case, is there one where you can set it to as little as 8 at a time?
Prentice
(1,784 Views)
Accepted by PrenticeK
Hi PrenticeK,
why don't you read the manual of the NI9403?
(You can define each single line of those 32 DIOs either as input or output…)
(1,779 Views)
Hi Gerd,
I did not realise there was a manual, my apologies.
But thank you for your reply!
Prentice
(1,770 Views)
Hi Prentice,
There is a manual for every hardware from NI!
(Atleast for all the stuff I bought…)
(1,753 Views)
