C and labview
Hello folks,
I have a hardware which is interfaced with the Code written in C language. I dont have time to make a GUI for the user interface. Can any one guide me step by step process for using the power of labview front panel with my C program. So that i can make the GUI......
Many thanks and i look forward to your reply or comments.
(3,024 Views)
Compile your C code into a set of DLLs and then call them from within LabVIEW.
(3,018 Views)
There is an extensive example called "Call DLL" that ships with LabVIEW that you can look at. Also, you can look at this KB article: Building a DLL with Visual C++.
(2,974 Views)
