C code for setting register values of NVRAM (plx pci chip). LV driver
 1) wondering if anybody know a C program to write values to register of NVRAM. the values of the register (1/0) will force the PLX PCI chip on the DUT board to reset and
      toggle between 2 modes for testing purpose.
 2) I already have a program that  allows programming the cygnus NVRAM written by someone else (not sure yet if nvram is on chip or dut board).
 3) usb-I2C (totalphase aardvark inst) is used to send commands to DUT board
 4) i have the plx api to be used with this chip control program in C. but i am totally new to C programming.
 5) i use labview and they have LV driver for aardvark I2C device. i can send commands to board. but i dont know how to send commands to chip for setting register values
     since plx has their own api and code for communicating to chip via i2c combined. I kind of follow the logic but cannot program this new requirement in C.
 6) how can i incorporate new code to write values to registers ( it is already writing some , but to different locations do i change them now or ?).
the 'write to reg sequence' is attached , along with C code file
I will be greatly thankful to you,
thanks in advance
Message 1 of 1
(3,795 Views)
