C code to labview array implementation
 Is it possible to change this C code into labview nested array with 2 inputs ? Smiley Sad
Thank you.
Message 1 of 13
(6,482 Views)
Accepted by montu.dada
Of course it is!
This code:
for(i=0;i<height;i++) {
      for(j=0;j<width;j++) {
            if(a[i][j]>240) {
                 a[i][j]=255;
            else {
              a[i][j]=0;
Could look like this:
You should be able to finish the rest Smiley Happy
Craig H. | CLA CTA CLED | Applications Engineer | NI Employee 2012-2023
Message 2 of 13
(6,467 Views)
Thankx Craig,
 Im new to labveiw so i'll give my best shot to complete and upload the VI here .Can you please help to review this final VI?
Thankx in advance. (Y)
Message 3 of 13
(6,441 Views)
That is a VI snippet.  You can drag the image to your LabVIEW block diagram and you'll have the code.  (Assuming you have LV 2013 since the VI was created as a 2013 version.)
Message 4 of 13
(6,436 Views)
What is the second input??
Here's a no-loop solution (assuming a single input of a 2D array). 😄
Or this (a little less universal. only works for unsigned integers)
Message 5 of 13
(6,432 Views)
Now,
  I couldn't figure it out to deal with if statements. Can tyo suggest me about this section please?
for(j=60;j<120;j++) {
     if(a[30][j+1]!=a[30][j]) {
         if(a[30][j+3]!=a[30][j]) {
             h_count=h_count+1;
Regards.
montu
Message 6 of 13
(6,400 Views)
You've already marked the question as solved. Why do that and ask basic question such as what is an if statement in LabVIEW. Click on the Options button to remove what you marked as the solution.
Message 7 of 13
(6,392 Views)
@montu.dada wrote:
Now,
             h_count=h_count+1;
Regards.
montu
You need 2 index arrays and a Equal comparison.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 13
(6,388 Views)
it that what you mean?
Thankx.
Message 9 of 13
(6,377 Views)
How can we initialize the for loop to 60?
thankx.
Message 10 of 13
(6,355 Views)
