CALCULATION WITHIN AN ARRAY
I have a 1D array. It is filled with approx 200 values in SGL. I have to modify all the data. When the value is negative I have to turn it possitive (1st step). Second step. All values < 1*10-6 must be set to this value (1*10-6). What is the best way/easeast to do this??
Rens
(2,974 Views)
Hi Rens,
the attached image shows one possibility.
Mike
(2,960 Views)
Or this:
___________________
Try to take over the world!
(2,939 Views)
Accepted by RvG
Hi RvG,
The 'Absolute' function will make your whole array positive. You can then compare this array with your value, setting to the value if below:
EDIT: Or just do it TST's way as its better 🙂
Rgs,
Lucither
Message Edited by Lucither on 05-05-2010 08:40 AM
"Everything should be made as simple as possible but no simpler"
(2,930 Views)
