CAN Frame in Project Explorer
Dear community
My former co-worker worked on a LabView-Project, which I assume now. I had to install all the programms new on my local PC. Now I have the problem that the Project Explorer does't display the CAN Frames properly. I also can't go to the properties or something else. There is only the possibility to explain the warning or to remove from project. You can see the warning in the pictures below.
Has someone an idea how to solve this problem? I have installed the NI-XNET drivers with the version 1.8.
(3,641 Views)
It looks like XNet 1.8 was released before LabVIEW 2014, which is what the version looks like you are using.  (next time mention this).  I'd recommend downloading and installing the latest version of XNet.  It usually supports the last 4 or 5 major versions of LabVIEW.
EDIT:  Here is a link to the 2014 version.
http://www.ni.com/download/ni-xnet-14.0/4863/en/
(3,624 Views)
