CANNOT COPY VI FILE OVER NETWORK using win XP
All access has been granted and the file attributes are not read only. I can not copy vi file from a remote folder located on a host pc over a network, however I can copy any other type of file located in that same folder. Labview is not opened on either pc. I can copy a file from my desktop pc to the host pc, but once the vi has been open and saved on the host pc, I cannot copy the file back to my desktop pc unless I physically go to the host pc, link to a folder on my desktop pc and copy it. If the vi has not been saved by the host pc, I can copy the file over the network. whats up? It doesnt seem to be a windows file security issue because it only occurs with labview.
(3,054 Views)
Can you rename the vi file at remote PC?
(3,054 Views)
When at the remote pc, all files function as normal. I can rename, change extension, copy from folder to folder, delete, but try to do this from a networked position not possible
(3,054 Views)
