CANopen PDO PCI Series 2
I am communicating with CANopen from mi NI PCI CAN Series 2 and an HBM module MP55. This module provides a CAN interface with PDOs. I've tried with the NI example CANopen Receive.vi but I only get messages from the interface when I disconnect the connection and reconnect but no continious data from the module. How can I establish a continious communication with the current data? The module says that it is ready for PDO communication - but how can I start the communication programmatically?
Any hints?
Joachim
(3,913 Views)
Accepted by topic author Joachim082
Dear Joachim,
have you installed the NI CANopen LabVIEW Library? If so, there are very nice examples in C:\Programme\National Instruments\LabVIEW 8.5\examples\CANopen\canopen.llb - especially ApplicationExample.vi shows how you would use it.
Hope that helps!
Best regards
Philipp R.
(3,893 Views)
Well, I guess you should switch the equipment to operational mode. Actually I don't have this library, but I do this task with simple CAN vi's
Take a looked to part of my code. It works well...
(3,395 Views)
How can I get a trial version of LabView CANopen Library? Does anybody knows?
(3,394 Views)
