CD create pid series model.vi
hi..
i was working with the 'CD create pid series model.vi' trying to make a pid out of it.. i was trying to connect the CD create pid series model.vi to SI model simulation ptbypt.vi so as to see it's response to error signals? but i cannot wire them together as the cluster size (2 and 21) are different..how can i overcome this ?
(3,966 Views)
Hi ajaleelp,
you can use "unbundle by name" and "bundle by name" to create the cluster you need.
Mike
(3,962 Views)
hi mike..
  i was checkin out your suggestion.. but then...i couldnt understand it properly.. my problem is..just to make myself more clear...the first vi (CD create pid series model) returns a cluster of 2 elements which represents a transfer function..but the second vi for model simulation is asking for a system model as a cluster of 21 elements..can u please clarify your suggestion..
regards..
(3,959 Views)
Bundle and unbundleHi ajaleeelp
Check this.
Message Edited by Baji on 04-03-2009 01:44 PM
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
(3,953 Views)
hi balaji.. if i have guessed right ur example is about combining a cluster of 4 elements to that with 2 elements rite and getting a bigger cluster rite? what i need to do is connect a transfer function system model ( which is said to be a cluster of 2 elements) to the input of another vi which accepts system model as cluster of 21 .. no need of combining clusters..just one vi's input to the other vi's output...
(3,942 Views)
can u post both the clusters?
Balaji PK (CLA)
(3,932 Views)
